RCU Forums - View Single Post - Transporting Planes
Old 10-17-2007 | 11:08 PM
-pkh-'s Avatar
-pkh-
Default RE: Transporting Planes
Here's my transport setup (see photos below). Two shower curtain rods from Walmart, the longer, sturdier ones (the shorter, cheaper ones are plenty long, but they flex more). Those are covered with pipe insulation. The rear rod is adjusted to pressure fit against the windows slightly (enough to keep it from sliding) and rests on the window sill. The front rod is adjusted to pressure fit against the windows slightly when the doors are closed, and it also rests on the window sills. String is also tied to the front rod on either side so the rod hangs from the hand grips on the ceiling, this prevents the front rod from falling down when you open a door. The wings go up on the foam covered curtain rods, while the plane fuses go below, with all my field gear.
ID:	785218   Click image for larger version
ID:	785219   Click image for larger version
ID:	785220   Click image for larger version
