RCU Forums - View Single Post - Some questions on lines
Old 10-18-2007 | 02:21 AM
Lou Crane
Default RE: Some questions on lines
EF,
Profile is a good way to start. You can build the bellcrank through the fuselage, and later convert that mounting plate to a mechanical 3-line system, or an on-board electronic system. The lines will be outside the wing, however. That's a relatively slight disadvantage, considering the obvious advantages for converting it to whatever throttle or other functions you want to try.
And, yes, as others have mentioned, the added drag of a third line - particularly an insulated 3d line - is often simply offset by shortening the radius by 5% or 10%. If YOU can handle the changed lap-time, where's the problem?
Luck!
