RE: Perry Pump and 2 stroke engine
I wouldnt tap the back plate, just take out the upper left backplate mounting screw and drill a hold through the case, and use the pressure fitting for the OS140, you can ge the fitting for about 5 bucks through towet hobbies, and its the same tread as the mouniting screw, but I do know some people have went the back plate route, but it is very thin
