RE: Do I need less downthrust?
Thanks, I will try to get the CG where I think it should be before I move on with any other test. Right now in level flight I need two clicks of up elevator to fly straight and level. When I roll inverted it takes a just a tad of down elevator. I haven't tryed the inverted 45 degree up line yet. I'll have to do that one. Thanks for the advice, after I get the CG set I'll work on the thrust lines.
