RE: Fuji 32EI problems solved.
Thanks for the info Bax. I will check to be shure the spacer is in correctly. I'm not sure about a transfer presure port in the spacer though. This 50 has a black tube going from the engine crankcase to a fitting on the carb & I assumed that it was providing the impulses to the carb. I'm gonna check it right now.---------joe
