RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 10-18-2007 | 02:24 PM
  #1773
RysiuM's Avatar
RysiuM
Default RE: gas fuel with glo plug no ignition
ORIGINAL: wingspan99
This may be just the ticket for my smaller engines in the 40-50 size range. It's amazing how much fuel I'll burn in my Raptor 50 heli.
There is one important aspect of different fuels (gasoline, ethanol and methanol) mentioned by av8tor1977. It is a fuel to air mix. Engine takes over 50% more E85l (by volume) compared to gas so the mileage of E85/glow mix is much worse than gas/glow mix. E85 gets a little more power but the amount E85 of fuel to produce the equivalent power to gasoline is still much higher. With E85 price only just a bit lower than gasoline it is something to think about before switching your car to FFV model.
The only one benefit of using E85 in our gas-glow conversion is that E85 is burning at lower temperature so it might be gentler to glow plugs. Other than that I don't see any reason to use E85. If you want more power then mix more methanol, less gas.
