RCU Forums - View Single Post - What causes conrod bushing damage?
Old 10-18-2007 | 09:14 PM
NM2K
My Feedback: (14)
Default RE: What causes conrod bushing damage?
ORIGINAL: DarZeelon
Ed,
'Egging out can be due to wear patterns... But it could also be a result of actual elongation of the 'yoke', whether it is at the top-end, or at the bottom-end of the rod, or both.
Excessive loading of the con-rod, from the piston repeatedly being pulled down, out of a seize at TDC (a very cold and rich break-in in a tight ABC type engine), will do that. Over-revving a four-stroke engine can also eventually cause that (unless floating valve-piston contact occurs before...), but this will take much, much longer.
Egging out due to wear is more likely to be due to excessive compression loading of the con-rod, like when running the engine for long periods on the verge of detonation; especially with a grossly exaggerated prop size.
...Or, as was suggested, spinning the engine with an electric starter, when it is 'nearly' hydro-locked...
That will wear down the near-sides of both bushings.
Why would a four-stroke rod deform from over revving when a two-stroke ran at the same rpm would not?
I can see why there might be valve problems because the springs are too weak to track the cam profile, eventually causing interference with the valve and piston.
Are four-stroke connecting rods built to a much lower standard because of anticipated lower rpm?
Ed Cregger
