Ultracote Backing Material?
I've read the descriptions for removing the clear plastic backing on Monokote. But a salesman talked me into buying Ultracote. When I opened a roll and unrolled it, I found a sheet of pretty heavy white glossy paper separating the layers of the roll. Not adhered to the Ultracote like the backing on Monokote, just a little electrostatic attraction.
Is the glossy paper the only thing that needs to be removed before cutting and sealing the Ultracote?? Or is there also a layer of clear plastic as with Monokote. I'm sure any of you Ultracote users will find this a pretty dumb question but will be able to answer it easily!
