RCU Forums - View Single Post - flybar settings
Old 10-18-2007 | 09:51 PM
Druss
Default RE: flybar settings
I suggest that you do radd's school of flight, in it you'll find out that most helis will pull to the left when you spool up slowly. If you can't get off the ground then check to make sure that you're getting enough voltage out of the battery.
