Loctite hysol 9462 source?
I'm getting ready to make the 9462 order. If you want to get in then let me know now. I tried in vain to get a better price on the gun and mixing nozzles. McMaster-Carr has the gun for $20. (Part# 74695A71) and the nozzles (6.1" long, taper tip, twist lock) for 88 cents each in lots of ten. (Part# 74695A25) You can order direct from them. For those of you really trying to save a buck you can get the hand plunger instead of the gun for only $1. (Part# 74695A27) Hand plunger is great for dispensing the adhesive for hand mixes. It might be a little tough to use the hand plunger w/a mixing nozzle attatched, especially if your adhesive is on the cold side.
Kevin
