ORIGINAL: skylarkmk1
Jim,
It is looking good, the rivet detail helps camoflage the fact that there are not as many ribs and the grey primer makes it look like the one in the photos I sent you.
Ha! Isn't that a coincidence! Just happens that the primer I had on hand was grey. That photo you sent was obviously just the ticket. I was able to enlarge and print it and mark each rivet in the print-out with a marker. It has been my bible. However, I did goof up in that the inboard end of the bottom has rivets up the rib edge. I forgot them!! Oh well!! Nobody's perfect[
