BLADE CP+, IT WORKED!
so i posted a few days back about how i was disapointed that the drive shaft in my cp+ got bent due to the interference that i got. well i decided tonight that i didnt want to wait to get a new shaft so i said what the hell ill try to straighten it out, it took awhile of reving it up without the rotor head and swash on it to see the bend, then slowing it down until the bend was facing forward. then i took needle nose pliers with electrical tape wrapped around each nose and gently bent it the opposite way of the bend in the shaft. it took awhile but it worked, so hopefully this is helpful to some of you new guys on here. oh and the tape on the pliers is to keep from scratching the rotor shaft, its a pain to get things like the swash and things on if the shaft is ruff so keep that in mind. anyways, whoever it was that said i could straighten it, THANKS ALOT, chris
