RCU Forums - View Single Post - Tamjets Gear failsafe Tip update for Spektrum radio
Old 10-19-2007 | 10:48 PM
SinCityJets
Default RE: Tamjets Gear failsafe Tip info update
ORIGINAL: tamjets
After you finish ATV adjust your retract system.
Binding your reciever again with gear up postion.
Now turn it off and hook up the retract servo to the gear failsafe. Turn on Tx and Rx to start the program sequence as instruction showing you.
After you got everything done.
To test the gear fails safe. Turn on your TX with gear up position and turn your RX.
The gear failsafe should be in the failsafe mode not allowing gear to go up.
Once you put your gear swicth in down position. That will disable failsafe mode.
Give it a try.
Tam,
My Tamglish is a little weak on this one.
"After you finish ATV adjust your retract"
So are you setting the failsafe on the radio to gear-up?
