RCU Forums - View Single Post - Convert GMS 120 glow to Gas
Thread
10-20-2007 | 08:29 AM
22
borna
Feb 2003
197
Boynton Beach, FL
RE: Convert GMS 120 glow to Gas
Even though is not necessary, but I was told if I want to run the engine with a lower oil 70:1 gas/oil ratio is better to equipped both bronze bearing with needle bearing. So it did it anyway for fun of it.
Also I was told the surface hardening of the crank pin may not be good enough to tolerate the needle bearing after maybe 100 runs, therefore I grind the pin to remove the surface hardening and then machine it to a smaller diameter and hard press a harden pin made of tool steel.
I have been so busy, therefore still haven’t had a change to run the engine. I maybe get a chance to run it this weekend, if not it will be 2 weeks from and provide more pictures.
Borna
Reply
Like
borna
View Public Profile
Send a private message to borna
Find More Posts by borna
View iTrader Profile
