RE: Newbies nitro question
Every time you start the truck you need the glow igniator. Even if the engine is hot.
To cut a zip tie just take your scissors and cut the part where it actually comes together. YOu know the big part. It might take a couple tries but you wont cut your rubber thing that way. Some cars need a zip tite some dont. If your airfilter sits on the carb tight you prolly can get away with out a zup tie. But if its loose you need it. If the air filter ever comes off stop the truck ASAP and find it or you are done for the day. Thats why its a good idea to keep extra. Also always clean your filters and keep them oiled. \
I usualyy pop my airfilter off put a couple drops in teh carb. THen pull the string like 3 times. Then i will do that 2 or 3 more times. I keep my engine oily...LOL.
