RCU Forums - View Single Post - What is the correct way to bevel the ailerons?
Old 10-20-2007 | 01:35 PM
flyX
Default RE: What is the correct way to bevel the ailerons?
Mark lines on them first . Lay a pin flat on the table. One line on top and bottom. Two lines for the thinckness part. This should give you a
general idea where the center is at.
use a long sanding block. Go side to side or horizontal, this will give you a more even bevel.
