RCU Forums - View Single Post - What causes conrod bushing damage?
Old 10-20-2007 | 02:23 PM
  #46
proptop's Avatar
proptop
My Feedback: (8)
Default RE: What causes conrod bushing damage?
Looks a lot like the K&B .40 rods I mentioned...whupped!
Over-heated... maybe by too much prop, and too lean?
The bottom end looks like either it has remnants of a bushing, but it might also be (no bushing ) just discoloration from varnish and or a little rust residue in the chamfer?
You can also see where the top end of the rod was rubbing the pin bore's boss in the piston...must have been fore/aft thrust loads...it may be a slightly bent rod too, or just rocking caused by the wallowed out hole?
