RE: Question about AR9000/DM9 Module
I haven't seen that amigo but have talked to Barry regarding something similar.
He mentioned, while working in his garage, that his surfaces kinda go crazy for a sec or two. he thinks it might be interference from a microwave in the house etc. but will do a 360 degree range check at the field.
My question to you is, how do I keep my gear from cycling when I turn my transmitter then airplane on.
should i turn on the receiver first then transmitter? i.e. force it into failsafe mode- gear down, surfaces neutral??
thanks
buck
