RE: Question about AR9000/DM9 Module
To answer both of your questions, usually re-binding them in your set-failsafe positions fixes this problem. You really have to bind the receiver twice. Once when you first put it in the plane, and again after you have all of your control surfaces set-up. Make sure all your sticks are set where you want them, the trim is set the way you want it, gear in the correct position, throttle at idle, etc. THEN re-bind the system again.
This will eliminate that problem.....same for the gear. Feel free to call me if you have any further questions.
Chad
702.521.8010
