ORIGINAL: strawboss
You are not telling me anything other then what is already written in the Spektrum manual. You did read my post right? The part where I said that I re-bound the system after I have flown it a bunch??
Actually Strawboss, I did read it right. And after reading it again, I still do not see where you said you flew it a bunch and then re-bound the system. I see where you took it out of one plane and put it in another and then re-bound it. However I did not see where you re-bound it TWICE AFTER installing it in the new plane. It must be re-bound AT_LEAST twice in each plane if you want your failsafes to be neutral and stop the initial control surface deflection and then movement into neutral.
If you have already done this, then there is nothing more you can do. Although I will say that in all of my A/C, none of them deflect then go to neutral after being re-bound.
Just trying to help.
