RE: Pull start substitutes?
All engines turn the same way . Not sure if the tiger drive will work with your roto starter . You are better off using a starter box anyway . To use a starter box you line up the chassis on the box and set the pegs to where the starter wheel will make contact with the flywheel on your engine . After setting it up , you place the truck on the box and press down which will engage the starter wheel and will spin the engine and start it using a glow starter attached .
