RCU Forums - View Single Post - My GP ElectriCub Kit project
Old 10-21-2007 | 09:37 AM
brsseb
Default RE: My GP ElectriCub Kit project
Good to hear you are feeling better. Your Cub looks good.
Ive gotten a few more hours work yesterday, the tail feathers are now covered and the hinges glued in place. Need to shave off some wood from the formers, the elevator and rudder links cant move freely yet.
I havent measured down thrust yet, Ill check the plans further and see if the prop is at the correct downward angle. If not, ill add abit of plywood under the two bottom engine mount screws to tilt it upwards abit.
When all this is done, ill cover the rest of the fuselage and the wing. Then its time to order ESC and battery.
Ill keep you posted on the progress.
