RCU Forums - View Single Post - evader diff.
Thread: evader diff.
Old 10-21-2007 | 03:00 PM
guver
My Feedback: (325)
Default RE: evader diff.
Hi, Welcome to RCU. It seems to be the long allen bolt that runs thru the middle of the diff? If it is this adjuster bolt then you may find a broken thrust washer under the head of the bolt. Probably a new locknut and thrust washers as a minimum. When going around a turn it will cause it to loosen up and then slip.
