RCU Forums - View Single Post - CP+ PROBLEM SOLVED!!!!!!!!!
Old 10-21-2007 | 03:02 PM
crazychris46dividedby2
Default RE: CP+ PROBLEM SOLVED!!!!!!!!!
yeah its great that i found that problem and solved it but now theres the issue of these crappy rotor shafts. just went out for a flight, everything was great nice smooth hover, a slight gust of wind caught it so i set it down and it tipped over to the left at very low throtle, and guess what, just from the blades gently hitting the ground, the rotor shaft bent. all i can say is GRRRRRRRR. its bad enough that i got into a hobbie that i cant really afford, but then theres the issue of these companies sell products that are cheaply made. id rather spend 400 on a blade cp that can withstand some accidental mishaps, than to have spent 200 dollars on a heli that cant handle the blades barely tapping the ground. i feel like ive wasted so much money buying this thing. i never had these issues with my blade cx-2, but now that ive upgraded it seems like the company is designing these things to break easily so that they can make money of you on the replacement parts, so eflite, go "F" yourselfs. chris
