Dago Red
Ohh about your retract servo question -you can use a standard without any problems-I used hitec 425 on mine -never a prob at all.If you wanna use a retract servo go with either the futaba or the expert brand-stay away from the hitec retract servo ,its not atv compatible(cant be adjusted with computer radio via travel adjustment if you need too ) good luck!
Steve
