RCU Forums - View Single Post - Dago Red
Thread: Dago Red
Old 03-27-2003 | 02:50 PM
Tecstar1
Default Retracts
My understanding is retract servos were specifically designed to operate a full 180 degrees and built to withstand the constant full torque force at the end of the throws. The retract servo does not allow end point adjustment?
Out here, I've read that some set ups may only require 160 degrees for operation, and if so, it sounds like a standard servo would be required allowing end point adjustment.
Want to make sure the retracts are set up correctly. Any info on how the retracts are in the Dago Red? Other models (H9, and other World Models) have alot of postings that show weak points, or having to tilt the gear forward to prevent nose overs.
Ron
