ORIGINAL: opjose
That's a 9x7 3 blade prop.
I wanted MUCH more speed on my Bobcat .25 so yesterday I flew it with two 3S 3900mAh battery packs in series to produce 22 volts.
I swapped out the motor for an 893KV motor capable of taking 22volts.
I also tried a 9x6E prop on this setup.
This increased the weight of the plane by about 5-6oz, but it still is under the glow engine weight.
On the ground the motor cannot spin as fast as the ESC is pulsing it, causing the motor to make a screeching noise and STOP at high throttle.
However once it unloads in the air, it does just fine.
The plane is a small rocket this way and I like how it flies.
I will be testing it with the 9x7x3 prop too.
If you want speed w/o the expense get a .30 GMS engine and put it on this plane.
It will do very well with the GMS.
Thanks. I'm not familiar with GMS- can you provide a link?
The one link I found- they're not listed as available anymore.
Perhaps you meant to find one used?
apreciate the help.
