RCU Forums - View Single Post - evader diff.
Thread: evader diff.
Old 10-22-2007 | 01:23 PM
cheech4's Avatar
cheech4
Default RE: evader diff.
ORIGINAL: evader22
yea i checked it out last night and the washer looked to be cracked and worped
also i am loking to put in the lowest turn as posible with out burnuing out the gears (i have a 10turn esc)
is their such thing as an upgraded diff gears?
thx
steve
yes, replace the diff gear and diff rings with the associated rc10B2 diff gear its stronger than the evaders diff gear, also use the B2 diff rings and use a 5x8 size bearing. also replace the idler gear and install the nitro evaders alloy idler gear, it fits.. do these things and you will have an evader that can handle the best brushles... i did this and i ran my evader as high as 48 mph with the mamba 6900.
edit: go take a look at the evader coalition is the largest evader thread in the world and probably the largest here on RCU also.. got questions post them there.
