RCU Forums - View Single Post - General field etiquette/rules questions
Old 10-22-2007 | 01:48 PM
Missileman's Avatar
Missileman
Default RE: General field etiquette/rules questions
ORIGINAL: jaka
Hi!
Hanging the frequency flag from the top of the antenna is no good! If windy the antenna will swirl all around!!
Hang the flag at the base of the antenna.
Yes, the frequency tag goes at the base of the antenna and if you drill a hole in the plastic plate you can put a tie wrap on it to make sure it won't fall off. You probably also have a red streamer and a plastic cap, this goes on the tip of your antenna and helps guage wind direction but more importantly it makes the tip more visible so no one pokes themselfs in the eye with it or something to that effect.
