RCU Forums - View Single Post - DZY 26cc problems - help
Old 10-22-2007 | 03:10 PM
soarrich's Avatar
soarrich
My Feedback: (98)
Default RE: DZY 26cc problems - help
Check that you haven't blown a crankcase gasket, I did and it had your symptoms. If you can see the crankcase with it running look for oil flowing from the seam line. Mine started out as small bubbles, the was an oil streak, then it blew out over 1/4 inch at one place and an 1/8 inch at another. I replaced the gasket with Red RTV no problem since that.
