RE: Saito rebuild question
Put the piston at Top Dead Center (TDC) The timing mark on the cam shaft points straight down and when it is orientated as such there is a small hole in the cam shaft that lines up with where one of the lifters installs that you can CAREFULLY hold the cam in place with an allen wrench, after you remove the lifter, while you install the cam housing to the engine block.
