RCU Forums - View Single Post - threading pushrod
Old 10-22-2007 | 08:48 PM
bruce88123
Default RE: threading pushrod
ORIGINAL: cyclops2
RO347.
This is a good time to learn about..... pull-pull........ control lines. Nothing needed except fishing line. No slop. easy to adj. Lightest system and costs nothing.
Can't do pull-pull on throttle and I believe (from a different thread) that this is what he has plans for.
If doing throttle use the treaded ends at the carb end and then use one of these at the servo
http://www3.towerhobbies.com/cgi-bin...4&I=LXE114&P=K
No soldering at all and solid connections with adjustments available.
