RE: threading pushrod
Since this is a setup for a pattern plane, have you considered using graphite pushrods instead of the steel? They're lighter, stiffer, and you just glue threaded ends into the CF tube. They're a little more expensive, but for the weight savings and additional stiffness, they're often worth the money.
Brad
