RE: How to bend wire landing gear...
The bolt on axles work just fine if you file a flat for the set screw and use a little thread lock.
I suspect your wire broke because you might have been trying for too tight of a bend.
Heating it up till it bends easily then quick quenching in light oil or water will restore enough temper that you won't notice the diff for most landings.
HTH
T
