ORIGINAL: Gravityisnotmyfriend
ORIGINAL: bigedmustafa
... spend a little bit extra and buy a real airframe. Balsa flies better...
This is coming from someone who has either never built a SPAD or never built a SPAD well. There is no reason a SPAD can not fly as well as balsa plane if built correctly. You'd be better off to go to the SPAD forums if want some less biased advice.
Point taken, Gravityisnotmyfriend, but the SPAD forums would merely be biased in the opposite direction. I have friends who build and fly SPADs and they enjoy the challenge of it. It's not an interest of mine.
You did take that quote of me out of context. I wasn't discouraging the original poster from flying a SPAD, merely indicating that an electric powered trainer would be better off if it were built-up balsa. I didn't see the point of spending $300+ on a brushless power setup so you could strap it onto $15 worth of PVC and Coroplast. I would guess that hundreds of new pilots learn to fly on glow-powered SPADs (either home made or Duraplane/Sturdy Birdy type kits) every year. I wouldn't talk the original poster out of this idea if he wanted to give it a try.
I also used the phrase "balsa flies better" a little tongue-in-cheek, I believe it's somebody's advertising slogan. I also happen to believe that it's true. When you build a SPAD that flies as well as a Sig Kadet LT-40, please let me know.
