RE: Need help putting engine in P51
The skimpy instructions and picture shows the engine mounted sideways. Is there any problem mounting it inverted? The only things that would be sticking out of the cowl would be a very small part of the head and rocker arm cover. If I do mount inverted do I then remove the part of the cowling below the prop output hole?
