Alert: Newbie Question about controls
This is true, although somewhat controversial and subject to different opinions. It is EASIER to learn 3 channel (with the rudder servo connected to the aileron channel), because the rudder won't roll the plane inverted as easily as the ailerons will.
The down side is that you have no roll control if you need it. So it's a give and take proposition.
