RCU Forums - View Single Post - Air bubbles between the carb and needle valve, Is it serious?
Old 10-23-2007 | 06:45 PM
B.L.E.'s Avatar
B.L.E.
Default RE: Air bubbles between the carb and needle valve, Is it serious?
Non remote needles can leak air just like remote needles, the difference is that with a remote needle, you can see the problem but with a non remote needle the problem is not visually obvious. Just because you can't see the bubbles, it dosn't mean the problem doesn't exist.
