RE: bvm smoothstop problem
Could the piston be pushing to one side? Is the piston pushed all the way in when the brakes should be off? If its not then it could be the brakes that are leaking. Or try re greasing the piston with that thick parkers O ring grease. If all else fails the tiny O rings will need replacing.
J
