RE: reassembling engine ???
I removed the cam, cylinder, piston, carb, pushrods. I have everything back together now. THe rods are in alignment with the rocker arms(removed the cover to make sure....everything is fine). Its just when i rotate the prop...I feel compression twice. Once then a small one right after. Seems to turn ok. Just dont recall noticing that before. Also hear a very slight tick/click after the 2nd compression. Wondering if its that i need to run the engine to reseat everything? I dont feel any resistance or grinding. Everything seems fine otherwise.
