RCU Forums - View Single Post - LT 40 to tail drager
Old 10-24-2007 | 06:26 PM
OzMo's Avatar
OzMo
Default RE: LT 40 to tail drager
mount your elevator horn slightly to one side so the tail wheel wire will clear. Bend a piece of 1/16 (long enough to go thrugh the fuse and make the wheel attatchment) music wire 90 degrees with about 1 inch to glass to the bottom of the rudder. don't glue till last though. drill a hole through the fuse (1/16" is plenty) straight down from the rudder hinge line. place your tail wheel bracket to match that hole. run the bent music wire thru the hole. glass the bent 1" end to the bottom of the rudder. asemble / bend the wire and tail wheel to suit the directions in the whell bracket (longer music wire required) BE SURE TO USE SPRING WIRE or MUSIC WIRE..... don't ask how I know
