RE: Typhoon 2 by ParkZone
Cjshaker is giving good advice. Servos can be easily removed.
Instead of tape, I use a foam-safe glue available at Michaels stores. It comes in a tube that looks like a tube of toothpaste. The name is "Hold the Foam". The glue holds the servo in place and can be later on removed easily. It just peels off from the fuselage and the servos.
I also use this glue on the Typhoon wing. I don't trust that little screw holding the wings together. The glue works great and can be easily removed if you need to remove the main wing.
