RE: Servo reqierments
Yes, don't worry about them in this size range. Just keep your linkage tight, and use closer holes on the output arm to give the servo more leverage, and you will be fine. Keep in mind, that with a more sophisticated servos comes more precise control not just more power / torque, along with the additional cost. Is it worth it to you on this plane, you must ask.
