Gluing firewalls
align them dry , useing a small very small drill bit drill four small holes one in each corner, after applying the epoxy, use either small screws or if you build on top of a hollow core door like I do , push t-pins all the way down to take the warp out ,go have coffee, no problem .
Highlander
