RE: DRIVE BELT FRICTION
Thanks for that info. Let us suppose that I am going to lubricate my belt - once - when it is new. Is Super Lube an acceptable lube for this application? How do you apply your lube? I have read that one way is to slowly rotate the tail rotor and spray a small amount of lube on the pinion or pulley while moving the belt.
