RE: Extreme composite Pro-Line
So changing the stab AOA should change the pitching to one degree or the other depending on which way the stab was moved. Should be easy to test that theory.
I admit I moved the stab on the first plane before I flew it. I'll check the them Sat and see how close they are to what Akiba-San said to put them at. From memory, .4 pos wing and .25 neg for the stab.
What I did was to fly the first one and set the CG close to spec's from the designer. Once I flew it I just moved the stab untill I got the elev trim centered. Might have been the wrong thing to do.
Tim
