RE: Welcome to Club SAITO !
Hi Xjet,
Thanks for your reply,the motor had new bearings & a new ring by a guy who knows Saitos,the bore was deglased using 600 grade wet&dry,when the motor was first run it "pumped'out fuel from the vent & the camshaft bearing housing then it seemed to also be coming out of the pushrod tubes,the moter was run inverted on a test bed.there is so much fuel/oil that it cant be used in a plane until problem is solved.the motor runs perfect except for the excessive fuel.I might mount the motor upright & see what happens,
Cheers,Keithie,
