RCU Forums - View Single Post - Seagull Ultimate 120 gas only thread
Old 10-25-2007 | 09:39 PM
lrglnman
Default RE: Seagull Ultimate 120 gas only thread
thats great busted!!!!! I got the servos installed I went with hitech hs645 at 6 volts got them installed last nite and all the control surfaces. got to hook up the pull pull rudder andhook up the elevators to the servos. my 125 saito should be here tomorrow. are you running any kind of on board glo plug ignitor. I was thinking of installing one and do you think the stock tank is big enough? where did you find the carbon fiber rods and fittings. if i had all the money to experiment and do it over again i would put the evolution 26 on this plane. it weighs close to the os120 by just a very few ounces. i painted my cabains midnite blue so they would blend in and was thinking of dooing the landing gear in that color too. just waiting for the paint to dry to see if i need to touch them up.I noticed you did not install the Ultimate sticker to the rudder I was thinking of doing the same thing. I used up most of the stickers but was wanting to do something nice to the rudder to personlize it. i have a beard so I thought i would paint the pilot to resemble myself. and add my signature around the cockpit .I really want to do smoke so in the future after i get it dialed in and dont crash it i may tackle that .I plan on low rates as well cause i want to do more scale manuevars and tricks. dont see many planes doing blistering rolls per second in real life. where is your cg located ? I noticed you used a wood prop why not an APC? and what spinner did you use. I guess i will rest awhile keep me informed of your progress and any changes you incorperate in it
