RCU Forums - View Single Post - YEE HAW!!!! My SisT FW-190 is Here!!!! "Build Thread"
Thread
10-25-2007 | 10:26 PM
21
fw190d9
My Feedback: (
1
Dec 2001
677
Seguin, TX
RE: YEE HAW!!!! My SisT is Here!!!!
Tripp, Keep the tail as light as possible, mount the elevator servos as far forward as you can. You WILL need nose weight on this bird. Mine needed 2 lbs of lead and all my servos are as far forward as possible. Also, the amount of carbon in the fuselage will give you radio problems. Go with a spread spectrum radio. I had numerous reception issues until I switched to 2.4ghz. No problems at all now. If you plan to use a motor larger than a G45, I highly recommend you pay attention to the elevator linkage. Make sure there is no slop as I have fluttered the tail on mine once already, stripping one elevator servo. Mine is a bit heavy at 30 lbs but flies just fine at that weight.
Pics of the build on my webpage;
[link=http://www.evoshangar.com]evoshangar[/link]
Evan Q.
Reply
Like
fw190d9
View Public Profile
Send a private message to fw190d9
Visit fw190d9's homepage!
Find More Posts by fw190d9
View iTrader Profile
