RE: Official Turbo-DAC build thread.
Make sure you turn off the glow plug power as soon as the engine is running or it will soon burn out. Try hooking up another plug to the panel. It should only pull enough voltage to power the plug, but if measured directly with no plug will read 11~12V.
